Starter relay
Old Aug 20, 2022 | 07:11 AM
Baird's Avatar
Baird
By your schematic, the start button feeds the solenoid directly. so you would need to relocate the wire from "31" that goes to the small post to terminal 3 or 86 and then wire as you have drawn. remember the case of the delco is ground so the mounting bolts need to clamp on an unpainted surface. Although my first connections would work I just reviewed a service manual and the bosch relay has this pinout, as suggested by Dan89.
85 ground
86 button
30 solenoid
87 battery
Eustus2000
Shovelhead
30
Sep 24, 2022 11:13 AM
Chopper Nate
Electrical/Lighting/Alarm
14
Feb 3, 2020 09:42 AM
TrickyNicky
Shovelhead
Oct 26, 2017 09:57 AM
captwill55
Shovelhead
Apr 13, 2014 07:36 PM
czornes
Shovelhead
Jun 6, 2011 07:13 AM
