Linkert float pivot screw
Old Nov 30, 2023 | 07:57 AM
glazedmule's Avatar
glazedmule
Stage I
Default Linkert float pivot screw
I did a carburetor clean and rebuild on my M-75 Linkert. Everything went fine and I can start and run the motor if I don't tighten down the float pivot screw. But if I put any torque at all on the pivot screw it holds up the float movement. Is there something that I'm missing? I followed the steps in the "genuine Harley Davidson" manual precisely and I referenced some youtube videos. I also tried using the old screw and not the one that came with the rebuild kit but that didn't help. So if anyone has any advice it would be greatly appreciated
Old Nov 30, 2023 | 09:00 AM
hellonewman's Avatar
hellonewman
I had the same problem with a repop kit so I reused the old pivot pin and and needle. Problem solved.
Old Nov 30, 2023 | 01:22 PM
Architect's Avatar
Architect
Do you have the float off center from the bowl, centered the edge will drag. Manual has a dimension, from memory 1/8" but check the book, might be 1/16", good luck.
Old Nov 30, 2023 | 02:57 PM
johnjzjz's Avatar
johnjzjz
Seen this more times then i can count - we take the side screw with out the post and sand it own a bit — till when the lever moves freely when tight and does not bind - too much and the float walks around and the needle un seats and over fills the float bowl - slight is all you want
jmcalafactor
General Topics/Tech Tips
Aug 11, 2018 04:16 PM
Dirty Dancer
EVO
Oct 25, 2017 08:38 PM
deewright
Apr 2, 2014 12:30 PM
ironhead_nick
Ironhead
Sep 3, 2009 02:47 PM
chengdave2003
Apr 6, 2009 10:24 PM
