Front drum drag
Old May 27, 2008 | 09:54 AM
Willy G.'s Avatar
Willy G.
Default Front drum drag
I'll post here too...My 1961 Duo Glide'sfront brake has drag in it, I can get a half turn out of the wheel before hearing the drag. I adjusted it but can't get the lever adjustment right (1/4 pull till it starts to work) without hearing the drag. Any tricks to doing this before I take a look at the drum, shoes, cable and return spring.
I've looked at the drum moving on a lift and there's maybe 1/16 of an inch movement (wobble) the shoes look good with no shinny spots or marks anywhere, the cable doesn't return all the way so I think that's part of it. The drum has 2 small spots where there's no contact and a small bit of rust built up. I'm thinking of turning the drum as I can't get enough adjustment from the cable with out drag. It seem as though the shoes are to big and the smallest cable ajustment makes it drag. I clean it up with break clean and grease the levers tomarrow. Thanks, *****
Old Jul 5, 2008 | 12:52 PM
FilthyLucre's Avatar
FilthyLucre
Default RE: Front drum drag
I had the same problem with my 68.&nbsp\\; Shoes looked good but would drag.&nbsp\\; Finally put on a new set.&nbsp\\; Solved the problem.
&nbsp\\;
[IMG]local://upfiles/65828/1B66D175A7274EA7BC2B4CB7C3404CE8.jpg[/IMG]
Hdbkstl
2018+ Softail Models
May 2, 2019 10:29 AM
harleyrider1990
Mar 10, 2016 08:41 PM
N.b.p.f.
May 22, 2013 05:44 PM
ItsTomFromNorthJersey
Apr 25, 2011 09:50 PM
MAX EVO
Nov 13, 2007 10:28 PM
