61' Fork Question
Old Mar 21, 2007 | 09:16 PM
kaptekarev's Avatar
kaptekarev
Default 61' Fork Question
The forks on my'61 have no detectable rebound damping. All I can feel in the spring pushing the forks up. Changing the fluid had no effect. I have manuals but tearing in have some questions. Is this a job I should take on? Hope do I support the bike so I can remove the forks? How much rebound damping did these things have? Do I need any special tools? Are there any specialty shopswere I can send the forksto be rebuilt?
Old Mar 28, 2007 | 09:44 PM
xcaret's Avatar
xcaret
Default RE: 61' Fork Question
Yes you have to block the bike up to remove the forks ,and the front wheel,and fender.If you changed the oil ,and your not leaking any ,you are not going to accomplish much by taking them apart .about the only thing that can go wrong is something that causes the oil to leak out the seals..You don't need special tools .Just read the manual real well before starting so you have a very clear picture of what needs to be done.
I'm not sure what exactly you are asking ( you should read your post before sending )I use a car sissor jack to raise my bike then slide a cinder block with a piece of carpet on it ,under the bike ,and let the jack down. Lately Iv'e been using a chunk of railway tie as I live by the tracks and you can turn them on their side to gain a bit of height if I want. As for specialty shop ,it's the local Harley dealer you need to be talking to .
maddyv
Mar 11, 2016 01:00 PM
harley-jones
Feb 3, 2015 04:05 PM
Shackleford
Oct 25, 2012 04:46 PM
deepsea
Mar 8, 2011 09:32 PM
1fatboy1
Sep 20, 2007 02:51 PM
