Parts Giant Giant selection of Harley Davidson aftermarket parts from exhausts to filters. Contact us for discounts exclusive to HDForum members.
Shorai BMS Battery Chargers
Old Apr 3, 2019 | 08:41 AM
Parts Giant's Avatar
Parts Giant
Premium Sponsor
Default Shorai BMS Battery Chargers
If your bike is currently equipped with a Shorai battery, this is the charger for you. If you don’t have one of these batteries in your bike, you can read all about the goodness of these modern, lightweight batteries on HD forums in this thread.
Shorai’s BMS Charger is the only dedicated unit for charging and properly maintaining Shorai batteries. It gives you the best possible battery charge in a simple, automatic manner. All you have to do is plug it in, hook it up to your battery, tell it how you want to power up your battery; store or charge – and then call it a day.
Once commanded, the BMS charger delivers energy to each cell within the battery in a way that provides maximum power output and preserves battery life. To do this, the electronics measure each individual cell’s actual charge, not the battery’s overall charge, and directs current as needed. In doing so, the best possible charge is achieved without the worry of over-charging the battery and consequently damaging it.
The charger is convenient, too. Simply plug in the included 12V lead to the power port on your Shorai battery and you’re hooked up. There are no alligator clips here. The extension cable that’s attached to your Shorai battery can be left in position and routed in a way that doesn’t require you to remove the seal or battery cover to plug it in. You’ll be able to conveniently plug in your Shorai battery whenever you park up the bike in your garage.
In the event you have any questions at all, you can ring us on 888.575.6570 anytime between 10am-6pm EST on weekdays, or just send a note to forums@partsgiant.com with SHORAI BMS in the subject line, along with the exact model and year of your machine and we’ll get back to you shortly.
Differentiating the BMS from conventional battery chargers, the system plugs into a port separate from the main terminals. In doing so, each cell within the battery is charged to maximum potential.
Every Shorai BMS comes with everything you need to charge your Shorai: power cable, adapter and easy-to-follow instructions.
__________________
Contact us for discounts exclusive to HDForum members. Some exclusions apply.
Email: forums@partsgiant.com
Phone: 888-575-6570 ext 817
www.partsgiant.com
jackietan
General Topics/Tech Tips
Dec 20, 2017 10:59 AM
UUNetBill
Nov 11, 2013 12:10 PM
Sandcrab
Electrical/Lighting/Alarm
Mar 2, 2010 10:36 AM
snuffer
Dec 3, 2007 10:26 AM
HDF Tech
Nov 1, 2005 10:00 AM
