Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Clutch Question
Old Aug 8, 2015 | 11:23 AM
jrplane's Avatar
jrplane
Default Clutch Question
I was riding in the hills of eastern Kentucky and noticed that as I slowed it was hard to down shift and when I was stopped the clutch was not fully disengaged. I stopped and adjusted the cable and that seemed to cure the problem. What could cause the sudden chance in the clutch? Everything was very tight.
Also when the bike is in gear and rolling power off the clutch lever has about 1/16" play maybe a little more, but when you are accelerating there is much more play. The clutch doesn't slip at all. Is this normal?
The bike 09 electra 103 original clutch, heavy spring, 45K, well maintained
Old Aug 8, 2015 | 11:40 AM
nevil's Avatar
nevil
The play in the clutch lever shouldn't change.
By adjusting the cable you are not adjusting the clutch, just the cable. I would start by doing a complete clutch adjustment when the bike is cold The final step in doing that is the cable adjustment.
See if it makes a difference.
fxstc1999
Aug 22, 2012 02:18 PM
VinnieFLHPI
Jun 20, 2012 04:22 PM
ricerocket71
Apr 16, 2012 11:50 AM
mi2az
Aug 1, 2011 06:03 PM
Nellybelle
Mar 31, 2008 01:50 PM
