Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Gear change
Old 10-11-2015, 08:33 AM
Deputyrb91's Avatar
Deputyrb91
Deputyrb91 is offline
Stage I
Default Gear change
I want to gear a 2011 Roadglide Ultra lower for more grunt off the line. Any ideas, besides changing primary pulley? Rick.
Old 10-11-2015, 03:27 PM
blue flht's Avatar
blue flht
blue flht is offline
Not cheap but, will give you what your looking for... Evolution Industries 49 tooth clutch basket and chain.
Old 10-12-2015, 10:06 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
There isn't much scope for doing that, unfortunately. There are no compensators available that I know of and the 49T clutch basket is darned expensive, which takes us to the rear belt drive. You can swap the 32T front pulley for a 30T, which is the smallest available and gives a 6% reduction in overall gearing. I'm told the stock belt will work with that (I hope so as I'm doing that myself!).
Old 10-12-2015, 02:43 PM
djl's Avatar
djl
djl is offline
Received 2,046 Likes on 1,509 Posts
Mixed reports on whether or not the OEM belt will work with the 30T; let us know if it works or not.
Old 10-12-2015, 02:45 PM
grbrown's Avatar
grbrown
grbrown is offline
Thumbs up
Wilco - it's going in along with a DD6, currently in transit.....
Old 10-12-2015, 08:57 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,875 Likes on 3,342 Posts
If you go to a 30/70 for the secondary drive you should be able to use the original belt and your ratio will go to a 3.15 overall. they say for every tooth on the trans pulley you can change the rear pulley 2 to maintain the original belt.
Edited because i first thought the rear pulley was a 66 but is a 68. However you can still do the 30/70 without changing the belt...You'll be going from a 2.87 to a 3.15 overall. Real nice change and still good for cruising if you have a 6 speed that would be a 2.71 in 6th
Old 10-16-2015, 07:06 PM
Seventy4blazer's Avatar
Seventy4blazer
Seventy4blazer is offline
What kind of rider are you? Will you miss the little bit of top end and mileage with a ratio change of any type?
I know that this is the transmission and drivetrain section, but what about a set of cams to help get a bit more low end power?
what else is done to your bike?
drm1978
EVO
10-11-2014 04:25 PM
seaton1450
12-29-2013 12:24 PM
Bbbadboy
11-12-2013 08:03 AM
scodill
04-04-2010 08:25 AM
quigley
06-21-2008 06:49 PM
Quick Reply: Gear change
