Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Reverse pattern shift.
Old Nov 3, 2016 | 03:40 PM
bettingpython's Avatar
bettingpython
Default Reverse pattern shift.
Mark do you guys make a reverse pattern drum to fit the 99-05 Dyna 5 speeds, how about the 07+ Touring 6 speed cruise drive?
I found N1 drums for those applications.
A couple of friends and I came the Harley side of life after spending a lot of time on fast bikes and we all kind of miss the shift pattern we were so used too.
Old Nov 4, 2016 | 08:23 AM
corliss@bakerdrivetrain.com's Avatar
We do, part number 2-5RRNS-A, it will also require our shifter pawl part number 555-56LD-A for a 01-05 Dyna. We do not have one for the cruise drives at this point.
Old Nov 4, 2016 | 06:07 PM
CarlosGGodfrog's Avatar
CarlosGGodfrog
A reverse pattern N1 for the 5 speed would be ideal. I have the N1, shift pawl. and billet forks and the package is great. However, I use a bellcrank to reverse the pattern mounted forward of the foot shift arm and Heim ends on the four ends.
bigtexasrob
Jun 25, 2016 12:22 PM
Next In Line
Apr 7, 2015 04:51 PM
98hotrodfatboy
Jan 10, 2015 08:57 AM
nkauf21
Aug 20, 2012 07:25 PM
BigDaddyMongo
Jul 28, 2010 03:23 PM
