Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
clutch
Old Jun 15, 2007 | 12:11 PM
dba1_2000's Avatar
dba1_2000
1st Gear
Default clutch
when I let my clutch out you never know when its going to grab.I have the bike off the floor and the the rear tire turns when it is in neutral or not I have changed the friction discs and springs and clutch hub ,and no matter where I adjust it it is not right.this is on a 1981 fxe. can anyone help? thx.
Old Jun 19, 2007 | 12:02 PM
pkp61's Avatar
pkp61
Default RE: clutch
Possible tranny sprocket spun on your shaft. Splines are gone. Its located behind your inner primary case. Take a large screwdriver and stick behind it and if it moves side to side and I am sure its your problem.
murdertrain09
Sep 24, 2014 07:39 AM
Velocity1
Jul 28, 2013 08:35 AM
50Flathead
Sep 30, 2012 06:09 PM
blackchipjim
Jul 3, 2012 01:57 PM
ULTHD
May 20, 2006 09:05 PM
