Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
85 fxrp tranny help
Old Apr 16, 2018 | 05:52 AM
Mike Petrill's Avatar
Mike Petrill
Stage II
Question 85 fxrp tranny help
Had to replace the tranny main shaft & inner clutch hub due to a broken woodruff key, (really chewed up shafts). Had all the parts laid out in order, ready for reassembly when everything got knocked off the bench. I'm 95% sure I have reassembled both the countershaft & main shaft correctly, but that 5% is really bugging me. I'd like to get the tooth count for every gear on the shafts just to be 100% sure I have the right gear in the right place. Does anyone know where I can get tooth count for each gear?
mikeytmh
Old Apr 16, 2018 | 10:45 AM
grbrown's Avatar
grbrown
Wink
I doubt if it is possible to assemble a tranny any other way than the right one! Your FSM should have enough info, there are also parts websites which show some info you may find useful.
Old Apr 21, 2018 | 04:22 AM
Mike Petrill
Stage II
Default Answer found
Found the answer. did a little research and found a great video on youtube that covers 5-speed transmission disassembly & reassembly. As for the tooth count for each gear, got that too, hopefully, this info will be useful to someone.
Main shaft gears starting from the trap door side - 4th gear 29 teeth, 1st gear 16 teeth, 3rd gear 27 teeth, 2nd gear 23 teeth.
Counter shaft (lay shaft) - 4th gear 19 teeth, 1st gear 25 teeth, 3rd gear 23 teeth, 2nd gear 27 teeth, 5th gear 17 teeth.
JamesYeager
Harley Davidson Videos
Jul 23, 2017 05:46 PM
hardheaded
Aug 2, 2016 09:16 AM
oldmantom
General Topics/Tech Tips
May 23, 2008 07:14 AM
DeJavu
Aug 13, 2007 10:14 AM
