Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Transmission noise
Old Jul 28, 2018 | 07:16 AM
hd_doctor's Avatar
hd_doctor
1st Gear
Default Transmission noise
2015 Roadglide Trans started to make a lot of clattering noise when rolling along freely not under acceleration or deceleration. Also bad when idling in neutral. It goes away when you pull the clutch in. Anyone know the problem? Not bad when cold. Worse when hot.
Old Jul 28, 2018 | 03:32 PM
grbrown's Avatar
grbrown
Wink
Check your primary chain tension. When doing that find the tight spot first.
JensWest
May 15, 2018 09:48 AM
Rev zombie
Sep 20, 2012 03:38 PM
Rev zombie
Sep 20, 2012 10:22 AM
Rev zombie
Rockhanger
Oct 12, 2011 01:42 PM
