Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
883 acts like it's missing a gear
Old May 17, 2020 | 01:41 PM
Eric McGee's Avatar
Eric McGee
Stage III
Unhappy 883 acts like it's missing a gear
Hello, I'm a fairly new Harley rider and have only done some minor work on my 1987 Sportster 883 Hugger, like carb mod and rebuild. I'm having some trouble right around 60mph. While everything leads me to believe I'm in 4th (top gear since I only have 4), I get that terrible growl like back when I didn't shift at the proper RPMs. Like I said, I'm pretty sure I successfully shift into 4th but now I'm worried to keep throttling with that tranny growl. I've tried several times to up shift when it happens, just in case it slipped, but it's spongy, as I'm guessing it should be with no 5th existing. Before I start taking it apart with my MO Manual, I really want to get some feedback from some experts. Thanks for any help you can give.
Old May 20, 2020 | 12:22 AM
Zanthamos's Avatar
Zanthamos
1 easy test that you can try is; bike on a Jack so rear wheel off the ground and spark plugs out, shift through the gears stopping at each gear and turning the rear wheel, feel the wheel while turning it to see if there is a change in tension in each of the gears; if the difference between third and fourth gear is no difference then you likely have an issue and need to investigate further. And what is a MO Manual?
Old May 20, 2020 | 06:15 AM
Eric McGee's Avatar
Eric McGee
Stage III
Default Bike jack
Thanks Zanthamos. I'll try that. ( Motorcycle Owner's Manual, aka MoM)
Old May 20, 2020 | 08:45 AM
Zanthamos's Avatar
Zanthamos
You need the service manual rather than owners manual.
Old May 23, 2020 | 12:56 PM
Eric McGee's Avatar
Eric McGee
Stage III
Default Wish me luck
Old May 24, 2020 | 01:55 AM
Zanthamos's Avatar
Zanthamos
I guess Clymer is better than nothing, no manuals are better than the HD Factory Service Manual.
salonik
Apr 21, 2018 08:47 AM
DublChen
Apr 18, 2017 08:54 AM
Bobby87
Jun 9, 2012 10:30 PM
tbeard4288
Aug 25, 2011 10:13 PM
Valor
Aug 27, 2010 05:27 AM
