Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
School me on reverse gear
Old May 7, 2021 | 01:35 PM
JonW's Avatar
JonW
Default School me on reverse gear
The old knees are giving me trouble, and it's hard to back up the Road Glide. I'm considering a reverse gear. Many of the posts here on that subject are old. It looks like with some of the units that you must engage neutral, and then move the lever on the RH side of the bike to engage reverse. How do you do that and hold the brake at the same time? I'm long-legged, so holding the rear brake with my right foot and trying to engage the lever at the same time might be an issue. My Road Glide is a 2015 6-speed. Any input would be appreciated!
Old May 7, 2021 | 02:39 PM
470004's Avatar
470004
You may want to consider Motor Trike's Reverse Gears. It has a engine cut off switch so you do not screw up the tranny if you have it in reverse and a forward gear at the same time.
http://www.motortrike.com/trikereverse.aspx
Skippy49
May 7, 2016 10:10 PM
questor
2014-2024 Touring Models
20
Sep 8, 2015 06:20 PM
jblass
Jun 7, 2013 12:48 PM
fxrhd
General Topics/Tech Tips
Nov 9, 2009 06:50 AM
shadek
Mar 15, 2009 08:09 PM
