Mini apes and new cables, removing slack 06 Electra
Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
In the middle of a handlebar swap from stock to 13 apes. Bought the LA choppers extension kit, trying to remove all the slack from the cable, followed the sticky and the JP cycles YouTube video. Still have zero slack removed. Adjustment on cable is backed out and derby cover removed to adjust the nut, still all slack. Any advice would be helpful because I want to ride my bike again sometime this century lol
Double check that you put the clutch cable receiver on the transmission back together properly.
yeah it was a bad install on the cable, plus I gotta find a switched wire, had a buddy help with electrical but it seems like he did a shotty job.
so Im in the process of taking it apart slowly, double checking everything as it goes back together, luckily I ordered a new freedom performance radial set and a K&N intake, so at least once Ive completely finished and tightened it up, itll be almost completely done
