Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
5 Speed vs. 6 Speed
Old Dec 27, 2007 | 08:23 AM
mbjam359's Avatar
mbjam359
Default 5 Speed vs. 6 Speed
What is the difference in the ratios? Is 6th like an overdrive or did Harley just tighten the ratios through the gears?
Old Dec 27, 2007 | 04:23 PM
bobcowan's Avatar
bobcowan
Default RE: 5 Speed vs. 6 Speed
Although 6th is a direct gear, and not OD, your final drive ratio is about the same a an OD gear. It's like adding another gear up top.
stevieg
Oct 10, 2014 02:29 AM
6farmer
Sep 19, 2012 03:31 PM
l.ray
May 5, 2008 10:27 PM
MAX EVO
Jan 17, 2007 01:16 PM
O5HOG
18
Jan 2, 2006 06:27 AM
