Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
BARNETT Clutch Scorpion
Old Apr 2, 2008 | 05:24 PM
Littleshack's Avatar
Littleshack
Default BARNETT Clutch Scorpion
I put a Barnett clutch in my 2003 Fatboy and every time I start it COLD I go to put it into gear and it jumps not a little but a lot. And ONLY on the 1st start of the day COLD. Any info would be great.
Old Apr 2, 2008 | 05:27 PM
t150vej's Avatar
t150vej
Default RE: BARNETT Clutch Scorpion
Wet or dry primary? What kind of fluid (if it's wet?)
Old Apr 2, 2008 | 06:07 PM
Littleshack
Wet and Red Line
Old Apr 2, 2008 | 07:27 PM
Dalton's Avatar
Dalton
I can be only two things, not adjusted properly or the plates are "sticking". I run a Primo Pro clutch and the recommended lube is Dexron II, good old ATF and have no problems such as you describe. The Redline is really a very good lubricant and sticks well to everything, so am wondering if maybe it has to do with the lubricant. The main purpose of lubricant in the primary is to help cool the clutch and lube the basket bearing, and not much else so any decent oil will work in there. I would call Barnett and ask them the question and see what response you get.
treetop333
Apr 8, 2018 01:48 PM
Velocity1
Jul 28, 2013 08:35 AM
lndeatr
Oct 8, 2012 01:40 PM
uglyd1
Apr 8, 2008 08:34 PM
buick455gs
Oil Archive (no new posts)
13
Jan 23, 2008 08:17 AM
