Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Primary Gasket Change Necessary?
Old 04-11-2008, 03:52 PM
MyFirstHD's Avatar
MyFirstHD
MyFirstHD is offline
Default Primary Gasket Change Necessary?
Time for my 10,000 mile service. I read all the post I could think of but what about the gasket? If you add the primary oil through the clutch inspection plate do you have to change the gasket? Nice to know before I start the job.
Old 04-11-2008, 05:08 PM
t150vej's Avatar
t150vej
t150vej is offline
Received 1,743 Likes on 1,137 Posts
Default RE: Primary Gasket Change Necessary?
NO. It's a rubber o-ring. The primary chain inspection cover gasket is another thing. You can usually get ny with good silicone sealer, but I'd recommend a new gasket at least every other time you pull it off.
Old 04-11-2008, 05:51 PM
dawg's Avatar
dawg
dawg is offline
Received 3,029 Likes on 1,743 Posts
For your 06 it's not a rubber o-ring. It's a disc. #25416-99C It is easier to add fluid on your scoot through the chain inspection cover, but at 10k service you will want to do a clutch adjustment also so you can stick to filling it through the derby cover. Cheap insurance to change the gasket, don't cost much.
Old 04-11-2008, 06:45 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
Your bike yes, new gasket. My bike has the o-ring and I have used mine 3 times...Just another of the many time & money saving benefits of the Dyna series...
Old 04-11-2008, 07:37 PM
oldfartjc's Avatar
oldfartjc
oldfartjc is offline
I bought a new Derby cover gasket anda primary chain inspection cover gasket before I did my 5000 mile service about 7 months ago and didn't use either one. The old ones looked good so I decided to reuse them and haven't had any problem with either one leaking. I willchange themwhen I dothe 10K service.
Old 04-14-2008, 07:44 AM
MyFirstHD's Avatar
MyFirstHD
The gaskets cost ~$10 or so. Could I have re-used the old ones? Sure, but since I had new gaskets I used them. The next time I think I'll also change to O-ring on the drain plug.
BTW, I put Rotella T syn in the primary. Based on other threads here (and independent lab results posted online) I'm thinking it is better to have a high detergentoil that cleans the moving parts than other oils that look brand new after 5000 miles but leave the grime inside the engine.
Windseeker
EVO
04-20-2018 08:16 PM
emperor wurm
11-15-2011 04:10 PM
beasleyiv
03-01-2011 01:08 PM
fendrix
07-10-2009 10:23 PM
albngore
02-23-2009 02:57 PM
Quick Reply: Primary Gasket Change Necessary?
