Outer Primary Gasket
Old Mar 1, 2011 | 08:55 AM
beasleyiv's Avatar
beasleyiv
Default Outer Primary Gasket
So I don't use a new derby gasket when I change my primary fluid, but what about the outer cover gasket? I'm swapping my primary cover and need to know if I should plan on a new gasket, or is the original reusable. I only have 5000 miles on the Lo.
Thanks
Old Mar 1, 2011 | 09:04 AM
Mike T's Avatar
Mike T
They are one use only.
Old Mar 1, 2011 | 09:08 AM
tmd442's Avatar
tmd442
Why risk it? Change it!
Old Mar 1, 2011 | 09:22 AM
cuda67bnl's Avatar
cuda67bnl
At $30 or more a pop, I'd reuse it. If it leaks, then replace it. I've had mine off more times than I can remember and haven't replaced it. That said, I went back with the same cover each time. It's your money and time though......
Old Mar 1, 2011 | 09:44 AM
V-Twins & Bowties's Avatar
V-Twins & Bowties
I've used mine more than once also, with same cover.
Old Mar 1, 2011 | 10:53 AM
ardakota's Avatar
ardakota
i reused mine but it seeped a little oil so i had to put a new gasket on it the cam cover gasket i reused and it didnt leak its not hard to pull off so it just depends on whether its worth your time to try it or not.
Old Mar 1, 2011 | 12:21 PM
rcmty's Avatar
rcmty
I've reused my primary gasket many times and never had a issue with it leaking!! I always check my o ring on the drain plug and if its not cut or torn I reuse it and never had one to leak yet!!! Its all how much money you want to spend to get that warm and fuzzy feeling!!!!
Old Mar 1, 2011 | 12:50 PM
JIMSFBL's Avatar
JIMSFBL
Thanks
OFF subject, but I just wanted to say that I'm not a fan of bags on a lo, But the set up you are running is the best I've seen on a lo so far. Very nice bro.
Old Mar 1, 2011 | 01:08 PM
beasleyiv's Avatar
beasleyiv
Thanks. I'm not a big fan either, and I run without them sometimes. But it is a comforting feeling knowing you got somewhere to stuff things if you're out and about.
I've been looking at the quick release options, but IMHO they all suck since they move the bags out too far. Looks like crap. I'm trying to figure something else out.
Henry89
Mar 1, 2016 03:26 PM
magazine
EVO
Aug 16, 2012 10:54 PM
emperor wurm
Nov 15, 2011 04:10 PM
troop
Oct 25, 2011 12:56 PM
fendrix
Jul 10, 2009 10:23 PM
