Primary Lube Change?
Old Jul 10, 2009 | 03:23 PM
fendrix's Avatar
fendrix
Default Primary Lube Change?
This is probably the wrong forum but I figure I'll get a quicker response in here...
I'm changing my primary lube, but didn't get a new O-ring or gasket. Is this critical to replace or should the old ones be okay? I figure it'll leak if it's not okay, but I'd rather not do the job twice. Thanks
Old Jul 10, 2009 | 03:25 PM
bberck's Avatar
bberck
I always replace the O-rings but the rubber Derby cover gasket can be reused if in good shape (dont think I would reuse the pancake style gasket).
Old Jul 10, 2009 | 05:48 PM
TMace's Avatar
TMace
I also replace the o-ring each time. I think it's only about .25 cents. If you have the o-ring on the derby cover I would keep using it until it looks bad. I have the gasket as I have an aftermarket derby cover. I just keep re-using it. Have changed my primary oil every 3000 miles and have 25000 miles on the bike and never had it leak yet.
SuperFastGlide's Avatar
SuperFastGlide
ive succesfully used mine (pancake)over 10 times and still no leaks..lol
if your o-ring isint ripped or anything youll be ok... but pick up a bunch for next time when your at a dealer..
Old Jul 10, 2009 | 06:03 PM
bberck's Avatar
bberck
Last oil change was the first time I used the pancake style so wasnt sure what it was going to look like on the next change.
Old Jul 10, 2009 | 06:05 PM
maddghost's Avatar
maddghost
My local HDealer never changes the orings,leaves them just more than finger tight and uses heat resistant threadlock on them! I bought a bag of ten and pinned them in my work area! 10$ And i change them the second they look iffy.
Old Jul 10, 2009 | 06:49 PM
moosh's Avatar
moosh
+1
must have been in and out of my primary at least 10 times and haven't replaced mine as well
Old Jul 10, 2009 | 10:23 PM
Ky Windage's Avatar
Ky Windage
Hope you have better luck getting your primary drain plug to seal than I have.
Did my 10,000 over a month ago and so far can't get it to stop leaking.
Just a drip every now an then but when I'm riding, it keeps splashing back on the rear rim, then the road dirt sticks to it. Looks nasty after several rides.
I didn't have any problems with my 5,000. No leaks at all.
This one is REALLY trying my patience. I've used new O-rings, tried with teflon pipe sealer, combination of pipe sealer and teflon thread tape... nada.
Tried ATV silicone sealer, still no seal.
By damn, tonight, I'm on my fifth try to seal the leak.
I've always felt the HD O-rings were a little thin, so I went to Lowes and bought several sizes to find what might work better.
This time I'm using a #8 O-ring... it's a bit beefier and fits tighter around the neck of the plug where it is undercut. Won't know if I'm sucessful until I can get out and ride it tomorrow. That is if the friggin rain holds off.
Also they were cheaper at Lowes. Bought 4 from HD and they charged two bucks, got a pack of what looks like 10 for the same ammount.
Guess I'll find out tomorrow.
Btw, I think Maddghost may be right about the tightening. I may have been going too far on the previous attempts. Mine isn't finger tight this time, but I went to about 14 inch pounds, which is still not very tight.
Henry89
Mar 1, 2016 03:26 PM
don g
Nov 20, 2011 10:46 AM
emperor wurm
Nov 15, 2011 04:10 PM
beasleyiv
Mar 1, 2011 01:08 PM
mjaw
EVO
May 28, 2008 10:26 AM
