Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Cam Chain Tensioner
Old Apr 23, 2008 | 07:49 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Default RE: Cam Chain Tensioner
Start cutting your oil filter open at 25k and look for orange debris.
Old Apr 23, 2008 | 08:27 AM
xxxflhrci's Avatar
xxxflhrci
ORIGINAL: Merlinii
Was planning to replace with the S&S gear-drive unit. While hunting one down at the performance shops, I found out that a problem has come up. The gear units are causing crankshaft runout, and they're holdig off on using them until more is known. That's not good.
Hogwash....The gear drives are not causing excessive crankshaft run out. The cranks are coming out of the factory with too much run out and make running gears, at least quiet gears, impossible for some people.
The sloppy cranks are mostly being found in later model bikes. The '99-01 bikes have a forged crank that is stronger and truer. The '03 and up bikes have a cast crank, which is inferior to the earlier crank.
Old Apr 23, 2008 | 08:28 AM
xxxflhrci's Avatar
xxxflhrci
ORIGINAL: Merlinii
. I suspect if you're not running synthetic oil, you might want to do this earlier than 40k as your wear could be greater.
Synth or dino doesn't matter. I've seen both prematurely worn ones or ones with very little wear coming out of engines using both kinds of oil.
Old Apr 23, 2008 | 12:21 PM
hounddog's Avatar
hounddog
ya thats crazyness ive never heard anything about the gear drives doing this, both on this forum and at local indy shops and fello riders. regaurdless im going with gears its a waste of time and money to deal with the stock setup. i run over 20k a year just in my commute soo i'll take my chance i guess cant be much worse than the tens shellin the oil pump and lifters?!?!?! [>:]
Old Apr 23, 2008 | 02:18 PM
sporty2003's Avatar
sporty2003
yes it is a crap shoot. some last and some don't why your guess is good as any.my niece husband has a 04 and mine is a 05 and we both had about 8000 miles on the bikes and they were wore. so replace with gear drive . but then again word has it. that on newer bikes the shoe's are better.but they say that alot.and there is some things you throw the book out and check any way.it can save trouble down the road.
Old Apr 25, 2008 | 09:06 PM
SC_Compact's Avatar
SC_Compact
Had mine inspected at 37,000.
The mechanic said they still looked good and to come back in a year.
Just got back from a 3200 mile trip to Key West and the bike ran great.
Old Apr 29, 2008 | 07:56 PM
HARLEYMAN69's Avatar
HARLEYMAN69
yup
it's a plot by HD
05 heritage and at 41k i decided to pop the cover; lo and behold, toast. there's good news though; it didn't get into the metal shoe parts.
replaced with the hyd. tensioners with roller chain; higher volume oil pump and a bunch of other new parts.
just turned over 45k and it's clicking a little but i think i'll re-adjust the push rods.
ride safe, please
Old Apr 16, 2013 | 04:34 PM
Sirbov's Avatar
Sirbov
Stage I
I'm changing the tensioners myself. I've seen cheap replacement shoes on eBay, I was wondering if anyone has tried them? And if anyone knows how much they are from the dealer
Old Apr 16, 2013 | 04:49 PM
2012SuperGlider's Avatar
2012SuperGlider
I have read that the reason it seems to be a 'crap shoot' is because of the initial quality of the chain. The individual parts for the chain are stamped, when the dies are fresh they stamp out a nice smooth part but as they age the edges become a bit ragged. This rough ragged edge wears the shoes much faster. Sounds like a pretty good explanation to me.
Old Apr 16, 2013 | 04:56 PM
soft 02's Avatar
soft 02
Nice thread resurrection! You have many options. Do some "tensioner" searches in the search bar.
