Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Changing Clutch Cable
Old May 17, 2009 | 02:44 AM
ArkiKen's Avatar
ArkiKen
Default Changing Clutch Cable
I am going to put stainless steel cables, brake lines, etc. on my 07 Road king. My question is do I have to remove the stock exhaust to remove the side plate to access the clutch cable?
Old May 17, 2009 | 08:33 AM
stroker1948's Avatar
stroker1948
Yes, you can't get to the bolts to torque back correctly if you don't.
Old May 17, 2009 | 11:17 PM
ArkiKen's Avatar
ArkiKen
Thanks Stroker I was afraid that was the answer
Old May 17, 2009 | 11:20 PM
BoomerBob's Avatar
BoomerBob
You can try to reach the bottom allen bolts with a short armed allen wrench which you can buy or simply make by cutting one down.
It might be easier to just take off the exhaust though.
Old May 23, 2009 | 09:50 PM
oct1949's Avatar
oct1949
They also make a allen rachet that has shorter wrenches.
The set comes with different size allen drivers about 3/4" long.
the rachet is smaller than a reg 1/4 drive rachet, and the allen drivers goes through a hole in the end Instead of snapping on like a reg socket..
used to use them on jobs with tight clearance back before I retired....
WWW.chapmanmfg.com these are very good quality plus American made, the same set was used for yrs and are still in good shape...
Pothole914
Nov 13, 2016 08:04 AM
berndog
Jun 3, 2013 01:22 AM
marvo75
May 6, 2013 08:30 AM
gliderman
Apr 14, 2013 03:32 PM
Chunker
Jul 7, 2011 07:21 AM
