Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Transmission main shaft nut tool
Old 10-12-2009, 06:12 PM
2cyclejohn's Avatar
2cyclejohn
2cyclejohn is offline
Default Transmission main shaft nut tool
Hey if anyone owns one of these sockets can you tell me how long it is and how big around is the main shaft?
I am making a tool for my roadking and dont really know the dimentions.
thanks
john
Old 10-12-2009, 08:59 PM
dawg's Avatar
dawg
dawg is offline
Received 3,003 Likes on 1,731 Posts
06 and earlier excluding the 06 Dyna use Mainshaft Locknut Wrench (HD-94660-37B) which is 1-7/8"
07 and later and the 06 Dyna use Mainshaft Locknut Wrench (HD-47910) which is 2-1/4"
Support spacers have been made out of kitchen cutting boards
Attached Thumbnails Transmission main shaft nut tool-socket.jpg   Transmission main shaft nut tool-nutsocket.jpg_thumb.jpg
Old 10-13-2009, 08:16 AM
mayanruben's Avatar
mayanruben
mayanruben is offline
Correct info, buy the socket the get a pipea nd weld on 7", then your on the money..suckers are expensive..stay down..ruben..1904
Old 10-13-2009, 05:51 PM
2cyclejohn's Avatar
2cyclejohn
I have a 1 7/8 short socket and a old 4 wheel drive deep socket that i can weld to thr short socket. I am going to cut out the 3/4 drive square in the short socket and install a bronze bushing there to support the tool.....what is the diameter of the shaft sticking out of the transmission once you get the ineer primary off???..
So far its a 7 inch tool ... is that right?
Bear with me in old....
\\john
LQQK_OUT
08-22-2017 04:05 PM
Eunoterpsia
11-30-2016 08:29 PM
Brick0044
01-04-2012 11:25 AM
coupe55
13
12-09-2010 07:13 PM
rejlaw
01-06-2009 08:39 PM
Quick Reply: Transmission main shaft nut tool
