Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
High Torque Bearing Kit
Old Jul 14, 2006 | 01:41 AM
redliner's Avatar
redliner
6th Gear
Default High Torque Bearing Kit
From Baker Drivetrain
http://www.bakerdrivetrain.com/dialu...BearingKit.htm
The 34091-85 inner bearing race has been used on Big Twins since 1985. The inner primary bearing rides on this race. By design, this race press-fits onto the transmission mainshaft. This system works fine for stock motors. 100 HP+ motors will make this bearing walk on the mainshaft. If it walks inboard, it will damage the maindrive gear seal and cause a transmission oil leak. If it walks outboard, it will cause a primary oil leak. Our high torque bearing kit eliminates this condition. Kit includes a precision honed bearing and seal.
DESCRIPTION | PART #:
High Torque Bearing Kit | 189-56
I have a 99 FXDL 100+ HP
On my inner primary the bearing (which was a very tight press fit) is between two snap rings, I cannot see how the bearing could move at all. Is there something I am missing?
I am repairing a transmission oil leak that started when I switched to synthetic oil. I also found out that the bearing race was split (I believe this is do to the main shaft nut being torqued too much). Has anyone else had this problem?
lhgdale
Nov 8, 2021 08:39 AM
cycler
Apr 27, 2017 01:37 AM
cowboybob56
Mar 23, 2016 04:07 PM
Locojuan
Aug 31, 2010 06:09 AM
BadDwg06
Dyna Parts
Apr 2, 2010 01:45 PM
