Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
06 Dyna
Old Aug 20, 2010 | 02:34 PM
HoolyNI's Avatar
HoolyNI
Default 06 Dyna
Hello, was wondering when alarm bells should start ringing regarding metal fillings on drain plug magnet.........was changing oil this evening and magnet was about 1/3 covered with very fine filings.
Old Aug 20, 2010 | 11:05 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Ok,
1. How many miles?
2 Which plug engine, trans, primary?
3. what oil are you using
Old Aug 21, 2010 | 02:07 AM
HoolyNI's Avatar
HoolyNI
Sorry meant to say Primary....wuz formula+ i drained out and theres just over 11k on the clock, but thats third time i've changed primary oil in 8k [or 3 years]
Old Aug 21, 2010 | 05:55 AM
dynarule's Avatar
dynarule
Your inner primary bearing is going out. HD will fix this on there dime. Are you hearing any kind of noise yet when the clutch is released at a stop? In 06 they had many problems with this bearing and issued a TSB about it and HD will pick up the tab to repair it outside of the warranty.
Old Aug 21, 2010 | 10:16 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You will always find metal shavings on the magnet on the primary drain. Most of the time it is normal due to wear on the metal clutch disks.
The inner primary bearing will tell you when it needs to be replaced.
Old Aug 21, 2010 | 11:39 AM
HoolyNI's Avatar
HoolyNI
Rang the dealer [am in uk] about the issue in preparation for ipb going but he says going by my chassis number there are no outstanding issues with my bike, have had no unusual noises coming from the primary as yet thankfully.
Old Aug 21, 2010 | 11:41 AM
HoolyNI's Avatar
HoolyNI
Was hoping it was just normal wear and tear am just over anxious regarding this ipb issue
fatchoppers
Apr 19, 2009 03:02 PM
azmcdude
Dec 5, 2008 05:23 PM
Cynic
Apr 19, 2008 10:22 PM
billybobber
May 19, 2007 02:58 PM
JerrySC
Jan 25, 2007 02:25 AM
