Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Engine/Trans clicking then shutoff?!
Old Aug 21, 2011 | 08:31 PM
bigdon03's Avatar
bigdon03
Stage II
Exclamation Engine/Trans clicking then shutoff?!
I was riding all day then took a 20 min break, started it up again, then a loud-continuous clicking took place for about a minute, then a loud final ping/click, then the engine shut off. Riding a 07' FLHX steet glide with the 96CI 6-speed. I let it rest for about 10 mins and it started up made it home about 5 miles. Any ideas what happened? and if I need to get something looked at? thanks
Old Aug 21, 2011 | 08:32 PM
TORQUEY's Avatar
TORQUEY
Sorry, no answer, but at least I can welcome you to the forum.
Old Aug 22, 2011 | 09:46 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Ok, when you re-started it did it make any unusual noises? Did you check the oil level?
Old Aug 22, 2011 | 10:34 AM
harleydwg555's Avatar
harleydwg555
Could be starter jackshaft sticking..you will have to pull primary cover and check condition of teeth. It happened to me sounds the same..good luck
ronbeejer
May 12, 2017 11:43 AM
jeffmyers6876
Dec 10, 2016 09:28 PM
dbell66253
May 5, 2012 12:23 PM
Thompson Gunner
Jun 27, 2008 10:49 AM
roxer
May 22, 2007 11:51 PM
