Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Remove Trans Shaft Nut
Old Mar 8, 2013 | 01:46 PM
prplglide's Avatar
prplglide
Originally Posted by Mrgrumpysdyna
Removing the nut will not help you removed the bearing there is only 0.100-0.125in between the bearing and the end of the main shaft gear. I just did this and had to cut a groove across the bearing with a 4in cutting disc and split the bearing with a chisel, just a word of caution if you go down this route take it easy with the cutting disc and dont cut too deep. Once you have removed the bearing you can deal with replacing the nut.
Hope this helps
Yeah. I thought about cutting the race off. I just figured the nut would have been easier..... why is nothing ever easy.
Old Mar 8, 2013 | 03:52 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You need to cut the race off, once that is done you can remove the nut, then you will be able to see what is inside the nut...
There is no collar of any type inside the pulley retaining nut, it is just a nut, like the picture in the link.
The nut in my picture came off via lefty loosey, and goes on righty tighty.
That is what you said in your other post about loosening the pulley retaining nut.
If you really did turn the nut counterclockwise, and it came loose, it was because something broke.
All five speed transmissions use a left hand thread on the pulley retaining nut.
Old Mar 8, 2013 | 05:16 PM
prplglide's Avatar
prplglide
Man, I hope your'e wrong about breakin something....
And I hope I loosened it the right way... I just can't recall now, as that was probably 6 months ago.
In any event, thanks for your help; I appreciate it!
As I'm going to work on it tomorrow, I'll let you know what I find. Hopefully, it will be good news.
Old Mar 9, 2013 | 07:04 PM
prplglide's Avatar
prplglide
Well, you were right. Those were threads inside of the nut.....
Why wouldn't HD make solid threads on the shaft??? There appeared to be a collar underneath the threads on the shaft...
I guess I gotta replace the trans main shaft, now. This was an expensive lesson.
Old Mar 9, 2013 | 07:37 PM
Dan89FLSTC's Avatar
Dan89FLSTC
It is not the mainshaft, it is the main drive gear. But before you buy any parts, disassemble the transmission so you can get an accurate idea of what you need.
Don`t panic, the transmission is easy to disassemble, and you can usually find used low mileage parts without spending a fortune.
Did you cut the bearing race off the mainshaft?
Old Mar 9, 2013 | 07:52 PM
prplglide's Avatar
prplglide
No. I managed to get the nut off without cutting the race off. It was quite the project, but I got it.
What else could I possibly need, other than the gear? Besides seals, and the like of course..
And I was just coming on here to edit my post from mainshaft, to mainshaft gear. Ya beat me to it.
You've been a HUGE help. I really appreciate it!
Edit: Any idea where to find parts? I just found a fear on ebay for $240!
Old Oct 25, 2015 | 04:33 PM
cowboybob56's Avatar
cowboybob56
I'm working on a 2007 glide with a 2 1/4" main shaft sprocket nut. I've broken a breaker bar and a 3/4" to 1/2" socket adapter. I've heated the nut liberally and attempted to turn the nut counter clockwise and all to no avail. My question is, can I use an impact gun to remove the nut? Or will it damage the transmission.
Old Oct 25, 2015 | 05:30 PM
RKGDCG03's Avatar
RKGDCG03
Veteran: Coast Guard
Yes you can use an impact gun. I would short bursts instead of banging on it for several minutes.
Good Luck
Old Oct 25, 2015 | 06:51 PM
nottaway's Avatar
nottaway
I think that nut is left hand threads... Righty loosey
Old Oct 26, 2015 | 04:50 AM
Dan89FLSTC's Avatar
Dan89FLSTC
The only left hand threaded nut on that driveline is the clutch hub retaining nut.
