Tetons /Yellowstone
ur route sounds pretty good. thanks
not in red stick,but on the tejas/la border.mom and bruther live in cajun country. we hate crowds so sept is probably going to be it for us. we don't mind cool,but not bitter cold.not enjoyable loose to much function to be riding twistie curvey roads.
Humidity in the west makes the summer very differnet, so expect about half (or more) of what you're used to. That means the air will cool a LOT quicker, especially after dark. Don't dress for summer like you would in LA, you'll want to be able to layer as you go up and down in elevation. In northern Utah, eastern Idaho, and western Wyoming you can expect the valleys to get into the 90s with humidity in the 15% and up range. At higher elevation (6000 to 11,000) expect temperatures to drop proportionally.
I make a trip to Yellowstone, Grand Tetons, and northern Idaho about every other year, and riding this side of the Rockies is GREAT. If you get a chance come up through southern Utah and hit Zion and Bryce national parks before working your way north up highway 89 (stay off I-15 if you can avoid it).
I'm with you on the crowds. If you're tyring to avoid them then late August is better than early. The early August time frame is when families try to get in those last minute vacations before school starts in late August. It also seems that early August is the prime time for the Prune-Platoon in their rolling living rooms trying to get in the scenery before they head south for the winter.
If you hit Yellowstone in that time frame then expect big crowds around the major tourist spots. Old Faithful will draw a couple thousand people at a time to see the eruption. There's lots of benches and spots to sit around the site so it's usually not too bad, but don't expect to be able to do it in a small group. When it blows folks enjoy the show and then disperse pretty quick. Not much to see between shows, and it's not nearly as "Faithful" as it used to be, so waiting times can draw mixed crowds.
Yellowstone and the Grand Tetons have decent roads, most of the time, but there are delays due to road construction or public works projects. Inside the park the roads are 2-lane, and if they shut one side down to repair the other then you'll face waiting times while they clear traffic each way. Longest I've had to wait was just over an hour.
As noted, Beartooth highway is decent, but there's some good roads away from the parks that are just as good. I personally like a couple of the state parks and scenic drives in eastern Idaho as much as those in western Wyoming.
If you want to get away from the crowds and can do some extra travelling then try Lolo National Forest on the Idaho/Montana border.
http://www.fs.fed.us/r1/lolo/
I highly recommend Highway 12 from Lewiston to Missoula (or visa-versa) ...
Also take a look at Shoshone Falls just south of Yellowstone ...
we have been trying to work our way back north since rita in 05.we took a Major hit right up the sabine(sab-eene) river 5 miles east of us.130 mph sustained winds with twisters mixed in. we want to clear the crowds ,but not get caught in too cold or storms so 1st two ,three weeks of sept is what we will go for. getting away from the heat & humiidty is our salvation and is what we look forward to.of course we like the gumbo,shrimp ,oysters and all that cajun cookin thats here.espically crawfish in season ! thanks for all the info.looks like a three week trip is in order!!!
Jeff
i'll print this tpic and use it as a written reference to plan & schedule off of.
In Cody we stayed in the Irma Hotel and there are gunfights out in the street just outside of the hotel each evening.
In Red Lodge, Montana we ate at the BearCreek Saloon and entertainment after we ater was Pig Races. What a hoot.
Good luck!
