Road Glide
While everyone is entitled to their opinion, I don't see any need to try to compare the looks to a "coffee" machine or anything else. I'm sure alot of people don't care for your bike but have respect not to call it names. Seems like you need grow up and keep your childish opinions to yourself.
Any feedback here pro or con on the RG vs the other touring models?
Also any feedback as to the 2009 vs 2010 RG? I think I like the 2009.
Thanks
You're on the right track.... rent both and then decide, which suits you, and your riding style.
If you're going 2 up? I'd suggest, taking the OL with you, and seeing what floats HER boat.... unless, of course, you want her to stay home. However, the ULTRA, might be the better deal, when the smoke clears, and the EG, SG, RG are all outfitted with the gear.
Looks are very important to a certain segment. And the RG, is "different" which seems to bother some folks. They are drawn to the common, and indistinguished.
In the end, it's YOUR bike, and you should get what you want..... pleasing the boys at the bar, is NOT the Road Glide's thing....
Russ
Nobody can tell if you're joking or not. Probably because of your inability to string together a proper sentence. It's a challenge to figure out what you are trying to say most of the time because you're always using the wrong words, like "there" instead of "their".
So when you joke, or insult, or whatever it is you're doing, you loose all your impact because it's like a guy who crawls out of the gutter and starts cussing at you. You just sort of keep walking and hope he goes away.
Really, I work with people who speak english as a second language and write way better than you do. My point is, your insults don't have much merit, considering the source.
I, personally, lean to the '09's as opposed to the '10 models. I like some of the changes (tail light, headlight bezel), but HATE some of the others (exhaust system and windshield are the biggies in that category...). Plus, you can get a better deal on an '09 at this point, too....
People either love or hate the RG. After one ride on one, you will know which category that you fall into....
Key factor with the RG is the fixed fairing which will make that the smoothes riding touring harley on the market you won't get the wind pushing you around like you will on a batwing bike no matter what the batwingers tell you that road glide will run straighter and truer on the highway at speed and when passing semis etc period.
Problem is most cant get over the shark nose look neither could i but my dads 09 cvo RG is growing on me.
As for 09 vs 10, if i were buying today which i wish i was i need a touring bike. I would get the 09 for a cpl reasons if iam not mistaken.
09 still had the dual exhaust which i like, still has the passanger foot boards, still has the cruise control. and there may be a few other items as well.
But the back end of the 2010 road glide looks better and most people will change the pipes anyway so there are some things to think about.
The EG will give you the additional storage but also give you a heavier center of gravity as you probably already found out since you road an EG and a SG. The SG and the RG are alot less top heavy. But to add the trunk it will cost you big time they are not cheap.
