15 speedo calibration
Old Nov 19, 2014 | 10:25 PM
Srrmc's Avatar
Srrmc
Default 15 speedo calibration
15 FLTRUCVO
FUEL MOTO X Pipe
recored Fulsac stock pipes
second license on PV
speedo reads 65 when doing 60....
I tried the old way for my 13 FLTRU by changing the VSS signal to no avail.....
Anyone got any ideas?
Thank you
Chris
Old Nov 20, 2014 | 09:20 AM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Originally Posted by Srrmc
15 FLTRUCVO
FUEL MOTO X Pipe
Thank you
Chris
On the 2015 bike the factory speedo calibration is 2105. To change this value you can do it 2 ways; in the WinPv software under Gear>Speedo cal, or by using Quick Tune on the PV device, it is under the second tab as VSS.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Nov 20, 2014 | 10:47 PM
Srrmc's Avatar
Srrmc
OK any one else....I did both...it doesn't work either way
Old Nov 29, 2014 | 10:44 PM
FXDXTSport's Avatar
FXDXTSport
I would put a lot of faith in what the guys at Fuel Moto had to say. I would guess you are doing something wrong. You may want to give them a call to figure out what it is.
Old Nov 29, 2014 | 11:23 PM
FinalShot's Avatar
FinalShot
Jamie, I'd like to add that not all 2015s are set at 2105. I have a CVO limited and the VSS from the factory tune is set at 2233. When I first loaded the tune you guys loaded, I was showing way to fast. I think 65 showed somewhere around 80-90.
Srrmc, what does your tune or PV show as the number now?
Old Dec 2, 2014 | 12:56 PM
Srrmc's Avatar
Srrmc
Default Thank you
I think I have it now
So here is what I finally had to do....first off the computer and the PV fix didnt work as previously stated.
So first off I changed the VSS to 1200 and that made my bike read 80 MPH at 40 MPH
Second I used a VSS of 3000 that made the speedo/GPS non-functional
Third I used a VSS of 2500...got a working speedo....now the external GPS reads 66 or 67 MPH when my speedo reads 60
I now have it at 2350 and it seems pretty close. Just have to fiddle a little more and i will have it!!!
Once again
Thank you
Old Dec 2, 2014 | 01:06 PM
FinalShot's Avatar
FinalShot
Try 2233 and see if that works. For my CVO Limited, that is +/- 1 with an external GPS.
samhallnc
Aug 6, 2018 08:39 AM
bigbush
May 28, 2012 09:52 AM
stbobshadow
Jan 4, 2012 08:31 AM
techmed
May 21, 2008 04:44 PM
SBRK
Jun 24, 2007 12:26 PM
