Speed Sensor Street Glide 2010 SE
Fellas, I have read so many post on my problem, speedometer not working, flashers not turning off automatically, bike stalling when causing and clutch pulled in..... and believe it is the VSS (Speed Sensor). Only change to manufacture stock FLHXSE is slip on RhineHarts. I found, I think, the Speed Sensor, (under starter, rear of trans, near center of frame.... How do you get to it to change it?? I have seen something on removing seat, battery box... but I see some high pressure lines and blah blah... looks like it might be over my capabilities or I could screw something else up. Any help will be greatly appreciated.
