Is this my speed sensor?
Old Oct 23, 2012 | 02:17 PM
bbflhrs's Avatar
bbflhrs
Default Is this my speed sensor?
My speedometer has been acting strangely and I researched the forums and found out I should remove and clean, or replace the speed sensor. The picture in the service manual and the parts manual doesn't look anything like what I see that is supposed to be the sensor located where the manuals shows. This is an 07 FLHRS. Can anyone tell me what this is and where the speed sensor is located? Is this my speed sensor?-speedsensor.jpg
Old Oct 23, 2012 | 02:29 PM
05UltraBob's Avatar
05UltraBob
That is not the speed sensor. That's the neutral indicator switch. The speed sensor is located at the rear of the transmission under the starter. It looks a lot like the crankshaft position sensor that is near the oil filter on the front of the engine.
Old Oct 23, 2012 | 02:42 PM
bbflhrs's Avatar
bbflhrs
Thanks for your response. The Manual shows the neutral indicator switch to be located on the other side. Do I have to remove the starter to get at the speed sensor?
Old Oct 23, 2012 | 02:44 PM
mikelikesbikes's Avatar
mikelikesbikes
Once you locate it and get it out it should look like an afro (for a lack of a better word). Just wipe it clean with a rag. I also like to use a small pen like magnet and get any other shavings that I can with it before putting the sensor back together.
Old Oct 23, 2012 | 02:57 PM
mikelikesbikes
Here is a pic.
Old Oct 23, 2012 | 03:01 PM
bbflhrs's Avatar
bbflhrs
Do you mean after putting the sensor back in or do I actually take it apart to clean it?
Old Oct 23, 2012 | 03:02 PM
bbflhrs's Avatar
bbflhrs
Originally Posted by mikelikesbikes
Here is a pic.
Oh, so it is right under the front of the solenoid. Thanks for all the help!
Old Oct 23, 2012 | 03:34 PM
TWIN CAM 96's Avatar
TWIN CAM 96
Buy a service manual for your bike there's alot of info in it to help you
Old Oct 23, 2012 | 03:37 PM
bbflhrs's Avatar
bbflhrs
Well, I must be a real dumb a$$ because I don't see it in the same location as your picture shows it. I guess I will disconnect the battery and pull the starter/solenoid unless anyone can make another suggestion.
Old Oct 23, 2012 | 03:38 PM
bbflhrs's Avatar
bbflhrs
Dude.....read my original post.
