Security Code
Old Feb 1, 2018 | 03:32 PM
robbie52's Avatar
robbie52
Default Security Code
Must be stupid, but I cannot put a security code on the new CVO. I follow instructions in the manual, but the odometer does not change. Any suggestions?
Old Feb 1, 2018 | 03:37 PM
TroutBum's Avatar
TroutBum
Make sure the FOB is out of range when you walk up to the bike.
Old Feb 1, 2018 | 03:44 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Which manual are you using, the service manual or the owners manual?
I can tell you that for the Rushmore models, the service manual does not give the correct procedure, but the owners manual does.
Old Feb 1, 2018 | 04:03 PM
skratch's Avatar
skratch
when you say 'cannot put a code in', are you referring to entering the pin override, or changing the pin override? makes a difference as they are different procedures.
if you are trying to enter the pin override, don't have your fob with you. if you are trying to change your existing pin, you must have your fob with you.
Old Feb 1, 2018 | 07:28 PM
robbie52's Avatar
robbie52
Using instructions in manual and trying to input my own pin on the bike. I did have the fob with me and could not change the pin. Not sure if a pin was ever input.
Old Feb 1, 2018 | 08:25 PM
mstrobes's Avatar
mstrobes
bike come with 00000
you need to change
Old Feb 2, 2018 | 03:09 PM
robbie52's Avatar
robbie52
So, after about the tenth try, using same sequence every time, I was able to change the code.
Old Feb 2, 2018 | 07:08 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Glad you got it. I would practice. The process / sequence has to be perfect. If you do any slight thing wrong it does not work.
Old Feb 6, 2018 | 02:34 PM
Hecster7's Avatar
Hecster7
6th Gear
Hey robbie52, I'm also having trouble changing my PIN. When you were following the procedures were you using the Kill switch (on the right handlebar) to cycle from Run-Off-Run-Off-Run? is the inforsystem turning on and off each time?
Old Feb 6, 2018 | 08:16 PM
robbie52's Avatar
robbie52
Hecster7
I responded in your post. I used the kill switch to cycle ignition following instructions in the manual. I think I cycled the switch fairly fast, the time that it worked.
Fred Marsch
Sep 21, 2018 09:16 PM
rattlebones
Nov 26, 2009 10:31 AM
azharleyrider86401
Jul 3, 2009 05:50 PM
jdsmitty10
Apr 22, 2009 08:52 AM
pete955k9
Jul 20, 2008 02:15 PM
