CAM upgrade...
Old Mar 21, 2018 | 01:32 PM
Taino1970's Avatar
Taino1970
Default CAM upgrade...
I have a 2015 softail deluxe CVO with the 110, with a FP3 tuner and true duals Samson pipes. I mostly ride solo and was maybe looking for a bit more bite. Anyone out here with some ideas?
Old Mar 22, 2018 | 11:07 PM
Bagged Out's Avatar
Bagged Out
Dave Mackie or fuel moto
Old Mar 23, 2018 | 04:23 AM
roadglider05's Avatar
roadglider05
Andrews 54 cams work very well in the 110". Compression wakes the motor up also.
Old Mar 23, 2018 | 08:03 PM
FLSTFI Dave's Avatar
FLSTFI Dave
My experience the 110, is most cams for that motor also need an increase in compression to be effective.
Also you need to decide what your looking for, more power on the left side, 3500 rpm or so and under where you usually ride, or more power on the right side, above 3500 rpm.
Old Mar 24, 2018 | 09:49 AM
30glock's Avatar
30glock
Dave what did you go with, when you changed on your 110?
Old Mar 24, 2018 | 07:22 PM
FLSTFI Dave
I like torque and power down in the RPM I usually ride in, 3500 and below.
First time I built the 110 CVO King, I had Don at HD street performance do the heads, he set the heads for a 10.8 compression using HD 10.5 pistons. We used AV&V beehive valve springs, woods lifters. I used the HD 259E cam, with HD 5.3 gmp injectors and a HPI 55mm throttle body with a 58mm intake. Turned out real nice, at 121 HP and 123 torque. Nice long flat torque curve, with it being over 100 torque by 2250 RPM.
Once HD came out with the 117 kit, I looked at it and decided it did not have enough compression. So I just bought the 117 Cylinders. Don at HD Street performance had CP build me some 11.4 compression pistons. I selected a woods cam, the TW 9B-6. Woods Alpha lifters. Had to upgrade the clutch to a Aim VP-SDR.
This gives a great torque curve, over 100 torque by 2300 RPM, over 120 by 2700 rpm and stays over 120 until 6000 rpm. Power everywhere, easiest bike to ride I have ever owned.
They key with building a motor is everything has to work together, the cam has to be for the compression, the throttle body has to be size right, not to big, and a good exhaust with correct back pressure. Everything works together. I could have had more top end with a bigger throttlebody, but would have lost low torque.
Old Mar 30, 2018 | 09:17 AM
GEORGEW's Avatar
GEORGEW
Here is a 110 CVO with a Cyclerama 570-2 cams .. Give Sheffer Performance a call at 812-401-8863
pharough
Screamin Eagle CVO Models
Apr 7, 2015 10:14 AM
Olsen185
Aug 31, 2014 08:28 PM
whitewolf001
Oct 2, 2012 12:30 AM
Newguy68
Sep 7, 2011 09:11 PM
GPHDXLC
Exhaust System Topics
11
Aug 5, 2010 02:38 PM
