Bought new in 2017,,,, and now with 11k miles I had a front lower rockerbox leaking,,, so with all that needed to be done to fix that,,, I made it worth my time.
Installed the Pro Pipe earlier this year & just did this last week,,, RS468 Cam, 2020 HD Updated Oil Pump, S&S Lifter Cuffs & Pushrods, Fueling HP Lifters, Andrews Crank Sprocket.
i agree with cam upgrade
I stopped at shop [ Drago ] last November 2019 after getting cut off a few times on the way home from a Patriot guard ride and asked about making my bike louder. I already had the full sac insert in muffler but needed a higher volume
We discussed the issue he said drill the cats and add a cam [he makes his own cams] and use a tuner and some s@s parts to fix up weak points on 2017 motor. Guy does motor work all over the country so i trusted his gut.
I am knocked out by the positive difference in sound but especially power [30% increase] .I have the same bike as you and very happy .
