Fullsac Baffles
Old Mar 1, 2021 | 08:07 PM
harley97's Avatar
harley97
Default Fullsac Baffles
I bought a set of 2.25" Fullsac baffles to put in my stock CVO Limited pipes. I have a couple questions.
1. What is the trick to getting the spot welds on the stock baffles off? I've been die grinding forever and it doesn't seem to be working very well. What bit should I be using or is there an easier way?
2. I bought the Techmat kit also. What are the advantages and disadvantages to installing it?
Old Mar 1, 2021 | 09:35 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
The trick is to be careful. I like to grind around the weld some and get the baffle free from the weld. For me this makes it easier to see what I need to remove and what not and I do not care about the original baffle missing some extra material there. Once there I can just grind the the welds down smooth and pull the baffles out. I use some 1/2" carbide bits on a small air grinder. As for the techmat to me if makes the tone out of the exhaust note much nicer sounding and a little quieter.
Old Mar 2, 2021 | 08:23 AM
doctorjoe's Avatar
doctorjoe
I, too, thought I was doing something wrong when taking out the stock baffles. Ya just gotta keep grinding. It’s takes longer than you’d think but the welds did pop out. Took me about an hour per baffle. It’s easy to think you’re just not doing it right...or perhaps YOUR’s were welded in with titanium. No, it just takes time and patience. worth it in the end.
Old Mar 2, 2021 | 09:21 AM
wethead103's Avatar
wethead103
Fullsac has a video on there website that shows how to remove the baffles. Good Luck
Old Mar 2, 2021 | 04:02 PM
harley97's Avatar
harley97
Feels like I'm just shining up the welds.
I watched their video, they make it look easy. Very misleading. This is taking forever.
Old Mar 2, 2021 | 05:37 PM
wethead103's Avatar
wethead103
I used a carbide tapered bit. Took me about 20 minutes to do one muffler. Don’t be afraid to put a little pressure on the die grinder while your grinding the welds.
Old Mar 2, 2021 | 07:38 PM
harley97's Avatar
harley97
I got one side done today. I will do the other side tomorrow. Hopefully it goes quicker and easier. Those welds take some doing.
thaghost
Apr 17, 2012 06:34 AM
aquaelvis
May 4, 2011 08:04 PM
Gary7
Sep 1, 2009 09:45 AM
klaybus
Sep 21, 2008 10:22 PM
gqchynaboy
Sep 3, 2008 09:10 AM
