I finally got a chance to take my Streetglide for its first ride. Right after I started on a short trip, I noticed the engine light was still on. Did a 12 mile loop back to home, bike seemed to run fine.
Did the procedure to check codes. I had a P1608 and a C0077. After a little research, the P1608 is for intermittent lose of power to the ECM.
I had pulled the main fuse a few weeks ago when I installed an accessory wire harness.
As for the C0077, that turned out to be for low tire pressure. I had checked and adjusted as needed before this shake down ride. I was able to clear both codes, so hopefully my CEL won’t be on again.
Only thing I don’t understand is what the PN numbers are? After the code is displayed, I had 0001809-01 come up for the P1608. For the C0077, 41000341F.
