Can anyone assist me in setting up No Toll Roads on my new CVO Street Glide in the navigation.' Full Settings' and 'About' are Highlighted but 'Avoid on Route' is not. In my 2021 you could go into the setting and tick any avoidances ie Toll Roads, Ferries etc. The owners manual doesn't help.
Regards
John
I get the same display with "avoid on route" not able to be selected.
If you touch full settings on the screen or use the the left OK button (right arrow doesn't work) you get another menu. Scroll down to "planning and travel" and under those options you can select "avoid when possible" for things to avoid from a list. Even with items selected the "avoid on route" option still can't be selected. Very weird, hopefully they get the bugs worked out.
There doesn't appear to be a global avoid toll road option until after I have set the destination. Once I set the destination I can access the "Avoid on Route" menu to set avoid tolls.
How do you set the GPS time to automatic? The GPS time appears to be set at 0:00hrs when the GPS calculates the arrival time.
To set avoidances you must have an active route. Question is does it remember it for the next route or do you have to set it every time? If it members it for the next route I am good with it. If it does not remember it they need to add a global setting for avoidances.
After riding the bike for a week the GPS "Full Setting" option "Planning and Travel" does have the global option to avoid tolls. Tab over to the fast/short/corners then tab down you find the "Avoid when possible" to select avoid tolls road, unpaved roads etc
