Have an issue with losing some oil and the Oil Light coming on. Fill oil up to correct level and after riding about a week later the light comes on and oil is low again. What could it be?
how many miles on the bike and how long have you owned it?
is this a recent development or developing over an xxx period of time?
the oil pressure light could be a faulty sensor
2017 Street Glide Cvo. Have an issue with losing some oil and the Oil Light coming on. Fill oil up to correct level and after riding about a week later the light comes on and oil is low again. What could it be?
Originally Posted by rwsbear
25,000 miles. This is a new problem. Oil check when warm about 5 minutes after shutdown. No oil on engine or floor. 200 miles between checks.
not quite a quart
so all of a sudden it's consuming ~ 1 qt every 200 miles? and no indication of oil externally visible anywhere? and it doesn't smoke like a chimney? this is really a mystery to me then, with only 25000 miles seems unprecedented to burn that much oil with no tell tale signs....tear that **** apart and rebuild the whole damn thing carefully!!!
