05 se cvo fatboy no spark
Old Sep 4, 2007 | 09:53 AM
jonny D's Avatar
jonny D
Stage III
Default 05 se cvo fatboy no spark
had my barrells and heads polished,,after putting the motor back together the starter works and everything else is working but no spark i've replaced the coil with a new one,,nothing got power to coil but no spark no codes come up,,am stumped any suggestions i would would be happy to hear,,,jonny
Old Sep 4, 2007 | 12:16 PM
tmitchellof PG's Avatar
tmitchellof PG
Default RE: 05 se cvo fatboy no spark
You might be better off posting this in the General section, which gets the most traffic or the Electrical section.
The only thing I could suggest is to clean and re tighten all your electrical connections and your battery terminals. I had a slow starting problem about 3 months after I switched out my rear signals. Found out my battery cable was a bit loose and had built up corrosion between it and the battery terminal. I was the one that did it and still find it hard to believe I didn't tighten the cable properly.
Good luck,
Tom
Old Sep 4, 2007 | 08:50 PM
detonator's Avatar
detonator
ORIGINAL: jonny D
Could be a ignitionfuse? I know thats a little obvious.
Tomhan
Apr 13, 2018 06:41 PM
tookiep
Screamin Eagle CVO Models
Aug 9, 2012 01:21 AM
Willis21
Jul 24, 2012 09:44 PM
cyclgoat
Electrical/Lighting/Alarm
Mar 26, 2012 04:27 PM
jonny D
Sep 5, 2007 10:32 AM
