CVO Springer - wiring
Old Jan 21, 2025 | 05:47 AM
Sunhill's Avatar
Sunhill
Stage II
Default CVO Springer - wiring
I have a 2008 CVO springer that I am restoring from an unloved state and I have two electrical challenges:
1. New Custom Dynamics headlight comes with 3 cables (Black (Gd), Red (Position), Blue (lo Beam). The OEM wiring harness has White, 2 x yellow, Red/White, Black & white. Am I correct in thinking I match Black to Black. Red/White to Red and White to Blue?
2. The turn signal circuit is not working - no light to front, rear or console for turn signals. I have checked the fuses and they all look ok. Just wondering where else I can start looking. I have changed the handlebars and the switches in the hand grips for new versions of both
Any help would be much appreciated
Old Jan 21, 2025 | 10:19 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Don`t try to guess your way through this, us the wiring diagram, HD provides them free online.
Avoid cutting into or tapping into a wiring harness, make an adapter harness if necessary.
2008 Wiring Diagrams
Old Jan 21, 2025 | 10:31 AM
Sunhill's Avatar
Sunhill
Stage II
I should have noted that I do have the service manuals for the bike and wiring diagrams. But I am struggling to identify the correct wires pairing for the Headlight and to diagnose the turn signal problem
Old Jan 21, 2025 | 01:23 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Head light wires are White (High Beam) and Yellow (Low Beam), on all Harleys.
The Yellow wire branches off to the Passing Lamp switch.
You need to be a lot more specific about these switches...
Old Jan 21, 2025 | 01:25 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Where on the bike are you finding these wires?
TraumaKing
Feb 7, 2021 01:53 PM
Bruin08
Oct 15, 2014 05:01 PM
BCarlin
Screamin Eagle CVO Models
Mar 16, 2014 04:56 PM
schumacher
Apr 30, 2010 12:09 PM
