2018 Road glide CVO
i have bought 2018 Road glide CVO - 117.
It has 18.000,00 miles.
I previously ownes 110 CVO Street Glide.
I am not happy with the sound of new bike.
I decided to ho with Tab Performance Zombie bafles, to remove the cat in head pipe.
I also decided to change camshat. I have dilema to go with RS 468 or S&S 475?
can i change only the shaft or i have to change anything else?
Do I need to do tuning (wich tuner)?
What you recomemd?
Thank you very much
Kind regards,
Bostjan
Either cam will work to improve power, but I would look at a Cycle Rama cam like the 480MT or 483. The exhaust set up you have chosen will hurt the low end torque, might want to consider different baffles. With a cam and proper tune, different baffles will still sound good but not hurt low end. The other exhaust to consider would be the KW 2/1/2 with louvered baffles in the KW 4.5” mufflers.
What you recomemd?
Thank you very much…
Kind regards,
Bostjan
H-D Milwaukee-8 117″ Camshaft Shootout
https://university.fuelmotousa.com/a...haft-shootout/
The Zippers Red Shift RS-472 and Wood Performance WM8-22XE Look like good choices to me.
Since it is a 2018, you have to consider the OIL Pump!
You need to change it if it's the OEM and I always go with 'new parts on new parts' so that would include:
- Pushrods
- Lifters
- Inner Cam Bearings
- gaskets & o-rings
I just realized you are in Slovenia, so If I were you, I would email Fuel Moto and start a dialog with them.
I can't speak highly enough for their Customer Service and Tech Support.
Good Luck with your build!
Last edited by Beartooth Rider; Nov 2, 2025 at 10:48 AM. Reason: Formatting& Oil Pump
