SERT or PCIII...
Hassle free USB communication - The Power Commander USB will instantly and automatically connect to the Power Commander Control Center software once it is installed. Simply "power up" the unit and connect the supplied USB cable to the computer and PCIII USB.
Onboard notes storage - The PCIII USB stores the notes from the map in the onboard memory. This makes it easy to see exactly which map is loaded. The notes, just as the map itself, are automatically retrieved upon connecting to the unit.
Individual cylinder adjustment - All PCIII USB units have a "cylinder trim" adjustment feature that allows you to "offset" fuel to one or more cylinders. Additionally, for advanced users, the PCIII USB allows individual cylinder mapping. Now each cylinder can be mapped individually throughout the entire rpm/throttle position range.
Enhanced "file compare" utility - The PCIII USB software allows you to compare two map files without the Power Commander connected. There is a numerical display as well as a brand new graphical display.
Easier to use "button adjustment" mode - The button adjustment has been made easier by introducing a "startup delay". This lets the user have enough time to start the bike and then switch the PCIII USB into "button adjust" mode. The ranges of the buttons are now displayed in the software. Simply connect the unit to the computer and press one of the buttons. Their ranges are shown on the screen.
"Expansion port" for upgrades and accessories - The "expansion port" allows easy connection of accessories such as our new ignition module, Quick shifter, Multifunction Hub, Pressure Sensor display and LCD display unit. Automatic map retrieval upon connection - As soon as you connect the PCIII USB to the computer and launch the software, the map installed in the PCIII USB will be displayed.
9V "Power Up" adapter - Every PCIII USB comes with a "power up" adapter which allows users to program and interface with the Power Commander on their desktop without being connected to the bike. Accelerator Pump - You can adjust: A) The amount of fuel to add, B) The number of engine revolutions during which fuel is added, C) The sensitivity of throttle movement under which the accelerator pump is activated.
New Features for Harley Davidso[/align]two new features for the Harley Davidson Power Commanders.[/align][*]The first new feature is "Rev X-tend". This will give you the ability to have an increased rev limit over stock without having to modify the bike's ECM. No longer will you need to take the bike to the dealer to have the ECM "re flashed" in order to have the higher rev limit your bike needs with modified cams, heads, etc. [*]The second new feature is "Start Fuel". This allows you to add additional fuel during startup. On heavily modified and/or large displacement engines (i.e. 124 Cubic Inch) extra fuel is sometimes required to ease starting. This is a software adjustable setting that makes it possible to increase the amount of fuel injected into the engine during cranking without making the idle overly rich once the engine starts.[/ul][/align]
