Itchy
Old May 19, 2010 | 09:44 PM
jamesamcnair's Avatar
jamesamcnair
Stage III
Default Itchy
I have a 2002 FlHRSEI Road King and am unsure of the handlebar diameter. With a tape it measures 1-3/16 inches outside diameter, is this considered 1" or 1-1/4 ?
Thanks
Old May 21, 2010 | 08:15 AM
dope_man_21's Avatar
dope_man_21
http://www.totalmotorcycle.com/photo...leRoadKing.htm
SCROLL DOWN TO THE RED FONT
• 2002 Harley-Davidson FLHRSEI Screamin' Eagle Road King
Specifications:
DIMENSIONS
Length 93.7 in. (2378.1 mm)
Seat Height (measure laden w/ 180 lb. rider) 26.5 in. (673.1 mm)
Seat Height (unladen) (692.1 mm)
Ground Clearance 5.0 in.
Rake 26.0 degrees
Trail 6.2 in. (156.3 mm)
Wheelbase 63.5 in. (1611.6 mm)
Tires: DunlopŽ Harley-DavidsonŽ Series D402
Front MT90B16 71H
Rear MT90B16 74H
Fuel Capacity (includes 0.9 gal. reserve) 5.0 gal. (18.9 L)
Reserve Fuel Capacity (warning light @ approx. 1.0 gal. for ESPFI models) 0.9 gal. (3.4 L)
Oil Capacity 4.0 qts. (3.8 L)
Dry Weight 741 lbs. (336.1 kg)
Vehicle Weight In Running Order (unladen) (332.9 kg)
Gross Vehicle Weight Rating 1259.0 lbs. (571.6 kg)
ENGINE
Engine S.E.Twin Stet Cam 95™ (vibration isolation-mounted)
Valves Pushrod-operated overhead valves; with hydraulic
self-adjusting lifters; two valves per cylinder
Bore and Stroke 3.87 x 4.0 in. (95.25 x 101.6 mm)
Displacement 95 cu. in. (1550 cc)
Compression Ratio 45 mm 9.4:1
Fuel System ESPFI ( mm throttle bore electronic fuel injection)
Air Cleaner/Filter Oval with chrome billet insert
high-efficiency, pleated paper filtration
Ignition Single-fire, non-wasted, map-controlled spark ignition system;
electronic breakerless with multiple advance curve matrix
Lubrication System Dry sump, internally mounted,
crank driven gerotor pressure and dual scavenge pump
with spin on 10ě pressurized oil filter
DRIVETRAIN
Primary Drive Double-row chain; oil bath; mechanical tensioner;
Carb and ESPFI 25/36-tooth sprockets (1.44:1)
Final Drive Gates aramid fiber reinforced Poly Chain belt;
32/70-tooth sprockets; 2.188:1
Clutch Multi-plate with diaphragm spring in oil bath
Transmission Five-speed,constant mesh
Gear Ratio:
ESPFI
1st 10.81
2nd 7.45
3rd 5.29
4th 4.13
5th 3.37
CHASSIS
Frame Mild steel; square-section backbone with twin downtubes
Swing Arm Mild steel, rectangular section with Forged Ends
Front Fork 41 mm Dia. Forks
Rear Shocks Air-adjustable
Wheels Bright Polished Spun Aluminum-Solid Wheels
Wheel Bearings Dual-sealed, automotive-style, ball-type
Brakes:
Caliper Type Four-piston front and rear
Rotor Type (diameter x width): Chrome Floating Brake Disc’s (with forged ends)
Front (DUAL) 11.5 in. x .20 in. (292.1 mm x 5.08 mm)
Rear 11.5 in. x .23 in. (292.1 mm x 5.84 mm)
Suspension travel:
Front 4.6 in. (117 mm)
Rear 3.0 in. (77 mm)
PERFORMANCE
Engine Torque 95.2 ft.lbs. @ 3500 rpm
ESPFI: 129 NM @ 3500 rpm)
Lean Angle (per SAEJ1168):
Right 33 degrees
Left 31 degrees
ELECTRIC
Battery Sealed, maintenance-free, 12-volt, 28 amp-hour, 300 cca
(per Battery Council International rating)
Charging:
ESPFI 45-amp permanent magnet alternator with solid-state regulator
(377 watts @ 1000 rpm; 572 watts @ 3000 rpm; 585 watts peak)
Starting 1.2 kw electric with Bendix-type engagement
Lights: (As per country regulation)
Headlamp Quartz halogen, 55-watt low beam, 60-watt high beam
Tail/stop lights 8w/28w, (5w/21w)
Turn signal lights 28w self-canceling, (21w)
Indicator lamps High beam, neutral, oil pressure, engine diagnostic light,
turn signals, low fuel warning
and security system
STYLING/CONVENIENCE
Engine Trim Silver powdercoat with chrome covers
Exhaust System Chrome Touring Mufflers wtih Chrome Billet End Caps
Seat Custom Leather 2 up seat with StingRay Insert and Adjustable
Detachable Rider Backrest with StingRay Insert
Passenger Backrest Detachable w/ StingRay Insert
Handlebars Custom 1.25” Dia.
Footboards Height-adjustable operator and passenger
Fairing none
Fairing Air Deflectors none
Lower Fairings none
Wind Deflector Dark Smoked LexanŽ/mini quick-detachable
Glovebox none
Instruments Electronic speedometer with odometer and resettable tripmeter;
fuel gauge with low fuel light
Stereo none
Antenna none
Rear Speakers none
Intercom none
CB none
Headset none
Cruise Control Factory Cruise with integrated Hand Controls
Handlebar Controls Start; engine cutoff; L/R turn signals; horn; hi/low beam;
cruise on/off and set/resume
Hazard Warning Integrated with turn signal controls
Electrical Power Outlet 4-pin accessory connector beneath seat
Tour-Pak none
Saddlebags Fiberglass with hinged lid and chrome slant latches,
volume: 1.2 cu. ft. (36L) per bag
Luggage Locks Saddlebag barrel-key, common with ignition
Fork Lock, Gas Cap Lock Barrel-key, common with ignition
COLORS
Candy Brandywine Radical Paint with Flames
Purple Radical paint with Silver Flames
WARRANTY
Warranty 12 months (unlimited mileage)
Service Interval First 1,000 miles (1,600 Km);
every 5,000 miles (8,000 Km) thereafter.
- Inspections of certain systems and components are required at 2,500 mile (4,000 Km) intervals -
apetterez
Jan 16, 2015 01:50 PM
HDF Tech
General Topics/Tech Tips
Oct 24, 2005 04:09 PM
HDF Tech
Oct 24, 2005 03:32 PM
HDF Tech
Oct 24, 2005 02:37 PM
HDF Tech
Oct 24, 2005 12:42 PM
