Fork oil issue
Old Jul 8, 2010 | 05:37 AM
Ben A's Avatar
Ben A
Default Fork oil issue
I have a 2008 CUSE3. I had it lowered 1" front and back when it was new. The bike is 27 months old with 53,000+ miles. I am headed to the smokey's in August so I desided to do some major service. New rear tire, brakes & rubber isolators. New front tire, brakes, fork oil and neck bearing adjustment. The 2008 service manual states to put 319ml. of fork oil in each fork. I removed the drain plug and top cap on each fork and let it drain over night. I pumped the forks several times to be sure they were empty. I replaced the drain plug with new ones, measured 300ml and started slowly pouring it in through the top. Both sides over flowed at 300ml. I cleaned up the mess and replaced the top caps on both forks. I pumped the forks several times and they seem fine. My question is is there another amount of fork oil for lowered forks? Is 300ml going to be ok? Thanks, Ben
Old Jul 11, 2010 | 07:49 PM
SteveO's Avatar
SteveO
I think the required amount the same regardless of the 1" lowering on not. A good dealer would know, Harley offers a 1" lowering kit for most their bikes and they would have the new specs.
Old Jul 12, 2010 | 05:41 AM
Ben A's Avatar
Ben A
I thought that the amount would be the same as well but a friend said to lower it puts more slider is in the lower fork therefore less room for oil. Any way I went with what I got in with the over flow and have already ridden 500 miles this weekend. I had a couple of hard braking events and no problems. The bike is much smoother than it was before. I will be headed to the smokey's next month. Got my fingers crossed. Thanks, Ben
Old Jul 16, 2010 | 06:34 AM
Ben A's Avatar
Ben A
I can,t believe no one can tell me the correct amount of fork oil required for forks that have been lowered 1" on a 2008 ultra classic cuse3.
Old Jul 16, 2010 | 10:51 PM
SteveO's Avatar
SteveO
If you don't have any luck with a dealer, try Progressive Suspension www.progressivesuspension.com or Traxxion www.traxxion.com both make motorcycle suspension systems and should be able to answer your question.
hbarleatherneck
Jan 19, 2010 05:23 AM
fastjoe
EVO
Oct 15, 2009 09:19 AM
BadPiggy
Mar 21, 2009 06:17 PM
danike
Mar 21, 2009 09:24 AM
jdvorchak
Jan 20, 2009 11:14 PM
