103 info needed
Old Jan 18, 2011 | 06:04 PM
62pan's Avatar
62pan
Arrow 103 info needed
Built up a SE 103 from a kit from the Harley dealer. Came with cast flat top pistons - 253 cams - SE103 heads - and much more to complete. Here's the thing, Engine is finished and ready to go back in and there were a few things I added for longevity. But I listed what my build was over in the Engine - trans section and was told by more than a few that this thing is gona be a SLUG as far as power because the compression is going to be way low with these heads and pistons, These are not items I picked they are Items Harley put together as There SE103 KIT. It has a advertised compression of 9to1, But I'm being told that's not gona happened with those heads because of the hemispherical combustion chamber and flat top pistons. Anyone had one of there SE103 apart and do you have the same set up --- Anyone else build one of the SE103 kits ? How does it run ? {this was a 04 88" twinkey to start}
ardbark
Oct 4, 2020 05:28 PM
rons73
Dec 14, 2018 12:49 PM
txphatboy
Mar 5, 2012 06:29 PM
txphatboy
Mar 3, 2012 10:54 AM
mkultra
Exhaust System Topics
Nov 3, 2006 05:07 PM
