help with back firing
Old Jul 5, 2012 | 12:16 PM
2009softailspringercvoowner's Avatar
Stage III
Default help with back firing
bought a used 2009 softail springer cvo , it has vance and hines exhaust no other mods known . the bike starts hard and spits and spudders revs high then calms down to normal idle. the bike back fires when up shifting or down shifting coming to a stop the engine seems to be running very hot and at stop lights sounds like its just running on one cylinder ive checked for error codes but none came up.
does this sound like it needs to be re tuned ?
any help would be very appreciated.
Old Jul 5, 2012 | 02:20 PM
scj's Avatar
scj
What you described is deifitely not normal operating circumstances so yes, get the bike looked at ASAP.
Did you ride it before you bought it?
Sounds like an air leak or just a really bad tune.
Old Jul 5, 2012 | 02:55 PM
Stage III
yes it was running fine when i bought it back in april
when i checked for error codes the only thing that came up was 2 part numbers
68921-07 (turn signal module )
67313-08 dont know what this is
i bought this from a dealership in michigan security system gone so no fobs only thing left is security ant
could this be the problem
Old Jul 23, 2012 | 06:20 PM
Stage III
Thumbs up seafoam
put 5 oz of seafoam in gas and bike no longer backfires and is running
awesome once again
Old Jul 23, 2012 | 07:27 PM
RANGER73's Avatar
RANGER73
That ethanol, will do it every time. You using premium fuel from a good gas station? Or are you cheaping out to save a few bucks. Some guys can get away with it some can't
flyboyron
2014-2024 Touring Models
Jun 5, 2017 08:48 AM
hitman1267
Jun 13, 2016 02:09 PM
marinepilot81
Apr 28, 2015 12:17 AM
Fatbobin_tn
May 18, 2013 11:34 PM
cmafolks
Aug 27, 2012 11:13 AM
