dyno #'s
stock 85 hp, 100 tq, xpipe and tune, 96 hp, 108 tq. I never had much luck with true duals, I found I lost torque. the thing with the xpipe is you need some scavenging and back pressure. I am making 100 pounds of torque at 2000 RPM and holding it past 4500, peak around 3500. I cant get my sheet to load on but I will try again later. Also big baffles are not the best option, my 103 stage 4 was a dog till I put 1 3/4 inch baffles in my pipes, along with an xpipe that thing put out sopme crazy numbers, 114 tq and 110 hp, 259E cam, 58 mm throttle, high flow injectors, 10.8-1 pistons, crazy head work by R&R. But the pipes and mufflers made a huge diference in performance. Good luck, for what your getting I would not feel bad. Be safe.
Not bad numbers, but the X-Pipe would make more numbers in both HP & TQ for you.
To be honest, If your scoot runs good, doesn't cook your right leg, and your seat of the pants dyno is good, I wouldn't worry too much about what the paper says.
However, I understand your pain of dumping all that money and coming up short on the numbers.
Although, switching to a X-Pipe (of choice) and a TTS Mastertuner will make a big difference!
Good Luck and Enjoy your new sled,
YB
YB
Ask your dealer about the Vance and Hines Xpipe. The pic of my bike shows my Xpipe.
Good luck. Let me know how you make out.
