New cvo roadglide problem!! Help!
Old Jul 24, 2013 | 10:14 PM
RC1500's Avatar
RC1500
Post New cvo roadglide problem!! Help!
My 2 month young screemn eagle roadglide has been stalling almost every time I come to a stop, happens if engine hot or cold...only mods done were removing OEM pipes and installing V&H tru dualswith rinehart tips. Dealer can't fix unless the "occurrence" happens in their shop. Thought that's what computer diagnostic for! Any input be great, thanks!
Old Jul 25, 2013 | 12:16 AM
Ryan2959's Avatar
Ryan2959
62 views and I'm the first reply?
First question: What tuner do you have and how was it tuned since you changed the pipes?
Cowboy
Old Jul 25, 2013 | 05:09 PM
puzzled1's Avatar
puzzled1
Same question as Ryan2959?
I'm thinking with true duals and no tune (if that is the case) that bike is way lean running on the factory tune.....
If it has a tuner in it than I'd be suspect of the map/tune.
Old Jul 25, 2013 | 08:28 PM
RC1500's Avatar
RC1500
Got the OEM super tuner pack at purchase.....always with bike when in service.....now first I was told tuner needed bc of new pipes, then told it didn't need to be remapped. I'm getting real frustrated. Up to this point they did great work another bike for me. They fixed lot of crap another lousy dealers wrench did, I'm surprised, yeah I spent far too much $ to put up with this
Old Jul 25, 2013 | 08:48 PM
flyingace's Avatar
flyingace
What size mufflers? 3 or 4 inch?
Buddy with a 2011 CVO SG had the same problem. He put 3 inch muffers on. Popping, stalling, etc. No retune. When he switched to 4 inch mufflers, all his issue resolved.
Old Jul 25, 2013 | 10:10 PM
RC1500's Avatar
RC1500
4" rinehart mufflers
Old Jul 25, 2013 | 10:17 PM
Talldog's Avatar
Talldog
If you didn't replace the air cleaner, shouldn't even need a custom tune. I doubt that's your problem.
Is the clutch releasing properly?
Old Jul 25, 2013 | 11:10 PM
RC1500's Avatar
RC1500
Clutch seems ok......it doesn't stall when I release clutch, it does when I'm holding clutch in...... ALSO if I pull over n put in neutral , let it idle for a bit it'll sometimes stall too. They're trying to say it's running too hot bc of high temp days , but that's bs because it'll stall on a 70 degree night .
Old Jul 26, 2013 | 09:38 AM
kojak's Avatar
kojak
Sounds like a sensor problem. Does the bike throw any codes?
Old Jul 26, 2013 | 09:57 AM
bigskyroadglide's Avatar
bigskyroadglide
have them check the temp sensor. I had a older bike that had a bad sensor and it caused stalling anytime i came to a stop
