2010 SE SG rear wheel
Old Jan 25, 2014 | 10:34 AM
cardboard's Avatar
cardboard
Default 2010 SE SG rear wheel
As you know the 2010 SE SG comes with a 180 55 18" rear wheel. You are limited to tire mfg and you have a low profile tire. Low profile tires are not right.
Has anybody changed the 18" rear wheel to a 16" rear wheel
Th measurements are
180 55 18 25.9" high
180 65 16 25.83 High
With a 16" rear wheel in a 65 series you can not run a Michelin or whomevers tire.
Why did HD design a 55 series Low profile.
To me its just so you come back to them
Don't like this setup.
Old Jan 25, 2014 | 08:15 PM
puzzled1's Avatar
puzzled1
I'm running a 16" on my 13 CVO.
I did it for the shorter tire to get my Bad Dad 4 1/2" stretched bags closer to the ground however with my new 6 1/2" stretched deep bags I may go with a taller tire to get the bags off of the pavement.
Have you looked into a 200 for your 18" wheel as opposed to changing out the wheel?
Old Jan 26, 2014 | 06:30 AM
cardboard's Avatar
cardboard
The Progressive 944 UT shocks would of dropped it an an inch.
No what is the problem is the low profile tire on the bike. its a 55 series.
With a 16" wheel he could run anybody's wheel like Michelin's tire.
He also has shorter legs. But wants to keep some ground clearance for the curves.
The 16" tire in the size I showed was suppose to be centimeters shorter than the stock tire.
Because it was a taller profile.
Old Jan 27, 2014 | 08:33 PM
'05Train's Avatar
'05Train
Funny, I swapped the wheels on my FHLTCUSE7 to Agitators specifically so I could run the lower profile tires. The bike handles better with them.
Different strokes, I suppose.
Old Jan 30, 2014 | 08:39 AM
bigskyroadglide's Avatar
bigskyroadglide
i have run a stock 16 HD rear wheel on my 12 CVO. IT changes the way the bike feels for sure. Seat of the pants dyno makes it feel like it has a bit more pep, kind of like changing from a 32 tooth pulley to a 31 or a 30.
other than that, and the looks vs the 18, it just was not my cup of tea. Better choice of tires is the only upside, I saw.
I did it only to wear out a 16 rear tire i had mounted on a 28 spoke rear wheel. Once the tire was shot, i changed back to the 18.
oh, it did throw the speedo off as well. based on my GPS it was off approx 3 MPH, but since the HD speedo is off by at least that much from the factory before i corrected it in the PV software, if yours is uncorrected it might be spot on I am certain each bike is different. All of mine certainly are.
Old Jan 30, 2014 | 11:17 AM
'05Train's Avatar
'05Train
Good point about the speedometer error. I was all set to re-calibrate when I put the 18s on, but it ended up being dead-nuts on.
Taranwanderer
Wheels/Tires
Jul 20, 2015 03:32 AM
kblackmon
Jun 4, 2014 06:40 AM
beau1981
Sep 4, 2013 09:10 PM
Swamphunter
Dec 30, 2007 08:28 PM
RandyM1911
Mar 9, 2007 09:39 PM
