Amplifier Decision For Detatchable Tour Pac
Old Mar 29, 2014 | 10:18 PM
Kawickrice's Avatar
Kawickrice
Default Amplifier Decision For Detatchable Tour Pac
I have an 07 CVO Ultra Classic with a removable Tour Pac (installed by the previous owner). I just got the bike and was wanting to get a detachable backrest for when I remove the Tour Pac. Since the stock amp is mounted under the Tour Pac when the trunk is removed all sound is lost.
I am kicking around weather to get a second stock amp and mount it under the detachable luggage rack/backrest I plan to purchase or to just redo the wiring to move amp to the fairing. Will I have room for the factory amp under a luggage rack? I really do not want to move the amp to my saddle bags if I can help it.
Old Apr 2, 2014 | 12:30 AM
Springer Dan's Avatar
Springer Dan
1st Gear
I'm working on the detachable tourpak setup now and am looking at this idea.
http://www.cvoharley.com/smf/index.php?topic=92875.0
I'm also changing to extended bags and fender as well which will eliminate the fillers between the bags and fender. This will free up the mounting bracket on the saddlebag support for amp attachment instead. I should end up with more clearance from the rear brake rotor than what is pictured in the link though.
Old Apr 3, 2014 | 06:37 PM
Beak's Avatar
Beak
Why don't you run one of the small digital amps and mount it in the fairing. That way you wouldn't have to worry about it. Check the audio section out, several guys have mounted it their.
Old Apr 16, 2014 | 01:39 PM
twentyways's Avatar
twentyways
Run an arc audio ks 125x4 mini made for fairing mount and a great amp find them on eBay and Amazon.
Adenton528
Audio Systems
Oct 15, 2021 07:58 AM
Eric Steward
Audio Systems
Jan 22, 2019 11:00 AM
Greatsteaks
Audio Systems
Jun 14, 2016 10:22 AM
axeman ultra
Mar 4, 2012 02:05 PM
sportsterleroy
Nov 10, 2008 06:31 PM
